Forum Members section DIY Ferduino controller TFT Shield
TFT Shield  [SOLVED]
Post Number:#1 Post Sat Feb 21, 2015 12:43 pm
Fernando Hi I have a problem with the implementation of the project I use an Arduino Mega and I get it moving asks you to insert the SD card , you get to keep saying anything is inserted sd card :ymblushing: :ymblushing:
thanks
Post Number:#2 Post Sat Feb 21, 2015 1:38 pm
Welcome Toni!
Which TFT shield you are using?
Have you checked this topics?
viewtopic.php?f=24&t=41
viewtopic.php?f=24&t=36
Post Number:#3 Post Sat Feb 21, 2015 4:48 pm
In Fernando Hi , thanks for answering , the screen is ITDB02 V1.1 , I removed the pins 50 , 51 , ​​52 , 53 , the shield of the TFT and I made the bridge between pin 4 and R16 . I've left it as it comes to le potentiometer 10R , as I understand it by the Terms and screen . Also I try to say that the screen without the ethernet shield .
-------------------------------- Last edited Sat Feb 21, 2015 5:55 pm --------------------------------
Hi Fernando, thanks for answering , the screen is ITDB02 V1.1 , I removed the pins 50 , 51 , ​​52 , 53 , the shield of the TFT and I made the bridge between pin 4 and R16 . I've left it as it comes to le potentiometer 10R , because I understand that by contrast screen . Also I try to say that the screen without the ethernet shield .
Excuse me for my English, which is very bad , I hope that 's understand
thanks again
Post Number:#4 Post Sat Feb 21, 2015 5:42 pm
If you haven't an ethernet shield the pins 50, 51 and 52 are needed for SD slot on TFT.
Post Number:#5 Post Sun Feb 22, 2015 7:32 am
Hello again Fernando, gifts now connect it back again the pins 50 , 51.52 to test if it works for certain what format should sd card and what size you being 64 Gbytes .
Thanks . :ymblushing:
Post Number:#6 Post Sun Feb 22, 2015 10:02 am
The size should be 1 or 2 GB!
Post Number:#7 Post Sun Feb 22, 2015 11:38 am
Connected the pins 50, 51, 52 to the TFT shield and it works now I need test the touch. Thanks
Last edited by Fernando Garcia on Sun Feb 22, 2015 12:30 pm, edited 1 time in total.
Reason: Spelling
