Fernando Hi I have a problem with the implementation of the project I use an Arduino Mega and I get it moving asks you to insert the SD card , you get to keep saying anything is inserted sd card thanks
In Fernando Hi , thanks for answering , the screen is ITDB02 V1.1 , I removed the pins 50 , 51 , 52 , 53 , the shield of the TFT and I made the bridge between pin 4 and R16 . I've left it as it comes to le potentiometer 10R , as I understand it by the Terms and screen . Also I try to say that the screen without the ethernet shield .
-------------------------------- Last edited Sat Feb 21, 2015 5:55 pm --------------------------------
Hi Fernando, thanks for answering , the screen is ITDB02 V1.1 , I removed the pins 50 , 51 , 52 , 53 , the shield of the TFT and I made the bridge between pin 4 and R16 . I've left it as it comes to le potentiometer 10R , because I understand that by contrast screen . Also I try to say that the screen without the ethernet shield . Excuse me for my English, which is very bad , I hope that 's understand thanks again
Hello again Fernando, gifts now connect it back again the pins 50 , 51.52 to test if it works for certain what format should sd card and what size you being 64 Gbytes . Thanks .
