Forum Software Ferduino code For succesfull installation read this!
Post Number:#1 Post Wed Jan 28, 2015 8:54 am
Topics: 12
Topics: 12
Netherlands
Ok since I have done a lot of trial and error I now have collected some point that were through out different threads that you need to do to be succesfull with intallation. I use the ferduino board with ITDB32WD display:
1. Make sure you have arduino 1.0.6 with higher vesions the code won't work.
2. To get callibration working with ITDB32WD display you have to change UTouch myTouch(6,5,4,3,2) to UTouch myTouch(7,6,5,4,3) in all code you use.
3. If you have issues with the web server not working right. Disconnection right after connection. Use a differend SD-card. I tried 4 sd-cards before i had mine working. (I now use 8gb class 10 format fat32).
As soon as I encounter more helpfull tips i will update this post.
Post Number:#2 Post Wed Jan 28, 2015 12:05 pm
Topics: 12
Topics: 12
Netherlands
If you are having sd-card issues, you can also try to solder J1 together on the back of the display.
For hooking up the temp sensors, use a mono jack. data to the tip and ground+vcc to the other part together.
Post Number:#3 Post Fri Feb 06, 2015 12:33 pm
Topics: 12
Topics: 12
Netherlands
If have the new ezo stamp, with ezo on the bottom left. You first have to change the baudrate from 9600 tot 38400. You do this by running the test code for the stamps and open the port of the stamp you want to use. Then enable carier return in the serial monitor. Then enter SERIAL,38400 , this should change to baudrate to 38400.
