Forum Members section DIY Ferduino controller Relay 16 or 8
Relay 16 or 8  [SOLVED]
Post Number:#1 Post Thu Mar 12, 2015 3:00 am
I have the pcf8575 all wired and and I am currently waiting on my 16 relay board to come in the mail. I just now noticed that there is a 8 relay board also. Is this still needed if I use 16 relay board? I plan on using all functions of the ferduino.
Post Number:#2 Post Thu Mar 12, 2015 10:03 am
A relay board with 16 channels should be enough.
I have a relay 7 channels and 8 Amper in my diagram because some devices need of high current as return pump, chiller and heater.
This question was explained here: http://www.ferduino.com/forum/viewtopic ... 1110#p1110
Post Number:#3 Post Thu Mar 12, 2015 2:42 pm
OK, the one I ordered is 10a. Do I need to change anything in the code to move the heater to the 16 relay board? Thank you again for the help.
Edit: Sorry just got up and a little out of it still. I understand now. Thank you.
Post Number:#4 Post Thu Mar 12, 2015 2:50 pm
Post Number:#5 Post Thu Mar 12, 2015 3:22 pm
Yes I changed that. The only one I didn't was the reference to line 843(https://github.com/FernandoGarcia/Fedui ... a.ino#L843) there is not a line 843.
Post Number:#6 Post Thu Mar 12, 2015 3:26 pm
Post Number:#7 Post Thu Mar 12, 2015 3:32 pm
OK, I had it all correct then. This is the 8 relay I already have.
http://www.dx.com/p/8-channel-relay-mod ... QHa3HMQHqA
Both the 8 relay and the 16 relay board are ac 250v 10a/dc 30v 10a.
Post Number:#8 Post Thu Mar 12, 2015 5:16 pm
What is the reason for having the return pump ran through a relay? I dont see anywhere in the GUI to turn the pump on or off.
Post Number:#9 Post Thu Mar 12, 2015 5:32 pm
The pump can be connected to a timer or adding some lines of code turn off it during a partial water change by example.
Post Number:#10 Post Thu Mar 12, 2015 5:55 pm
I'm sorry for all the questions. I understand everything else but the relay board. I overthink things sometimes.
Post Number:#11 Post Fri Mar 13, 2015 10:39 am
If all doubts were answered please mark this topic as solved.
