Forum Members section DIY Ferduino controller Problem with ethernet module W5100
Problem with ethernet module W5100  [SOLVED]
Post Number:#1 Post Thu Aug 06, 2015 2:25 pm
Topics: 9
Topics: 9
I uploaded a code ferduino and tested ping but in screen "Please insert a sd card", i have a tft display with sd card and i make a bridge of R16 to pin4, after i uploaded a code test W5100 "Ethernet module with W5100" from viewtopic.php?f=8&t=42 and tested ping and have return.
with the test code works, but with the code ferduino appear "Please insert a sd card", can anyone give a hint?
In topic ethernet shield and module, the pins are
MODULE ARDUINO
SO 50
SI 51
SCK 52
CS 53
VCC 3.3V
GND GND
But in w5100 module the pins are name a little diferent and i conected the pins
MODULE ARDUINO
MISO 50
MOSI 51
CK 52
SS 53
VCC 5V
GND GND
is correct?
If i pin off a 5V the ferduino open normal.
In back of ethernet module w5100 all pins are, V5, GND, NSS, RST, MO, SCK, MI, POE- and POE+.
My module is http://pt.aliexpress.com/item/TOP-Mini- ... 46986.html
man did a search found nothing, sorry if I let it go.
Thx
Post Number:#2 Post Thu Aug 06, 2015 3:07 pm
Have you removed the side of the resistor that goes to pin 53?
Are you using this values?
const byte ChipSelect_SD = 4;
const byte SelectSlave_ETH = 53;
Post Number:#3 Post Thu Aug 06, 2015 3:54 pm
Topics: 9
Topics: 9
Hi again Fernando,
Yes i removed the side of the resistor that goes to pin 53.
and my code is same:
//************************** Dispositivos SPI *********************************************
const byte SD_CARD = 0;
const byte ETHER_CARD = 1;
const byte RFM = 2;
const byte ChipSelect_SD = 4; // Comente esta linha para usar o Ferduino Mega 2560
//const byte ChipSelect_SD = 5;  // Descomente esta linha para usar o Ferduino Mega 2560
const byte ChipSelect_RFM = 69; // A15
Post Number:#4 Post Thu Aug 06, 2015 5:12 pm
Test the SD card with an example.
Post Number:#5 Post Thu Aug 06, 2015 5:42 pm
Topics: 9
Topics: 9
Upload the code SD TESTE
 #include <SdFat.h>
//const byte SelectSlave_SD = 4; // For ethernet shield
const byte SelectSlave_SD = 5;   // For Ferduino Mega 2560
const byte SelectSlave_RFM = 69;   // For Ferduino Mega 2560
const byte SelectSlave_ETH = 53;   // For Ferduino Mega 2560
Sd2Card card;
SdFile file;
SdFile root;
SdVolume volume;
float temp;
float tempe;
   int16_t n;
   char buf[8];
   pinMode(SelectSlave_RFM, OUTPUT);
   pinMode(SelectSlave_ETH, OUTPUT);
   digitalWrite(SelectSlave_RFM, HIGH);
   digitalWrite(SelectSlave_ETH, HIGH);
   Serial.begin(9600);
   card.init(SPI_QUARTER_SPEED, SelectSlave_SD);
   volume.init(&card);
   root.openRoot(&volume);
   while(!Serial)
      ; // wait for serial.
   if(file.open(&root, "LOGTDIA.TXT", O_CREAT | O_APPEND | O_WRITE))
      Serial.println("Writing...");
      Serial.println();
      for(temp = 27.5; temp > 22.0; temp -= 0.15)
         file.print(temp);
         file.write((uint8_t*)"\0", 1);
         file.write((uint8_t*)"\r\n", 2);
      for(tempe = 22.5; tempe < 28.0; tempe += 0.15)
         file.print(tempe);
      file.close();
      Serial.println("Done!");
      Serial.println();
      Serial.println("Can't open.");
   if(file.open(&root, "LOGTDIA.TXT", O_READ))
      Serial.println("Reading...");
      Serial.println();
      delay(5000);
      while ((n = file.read(buf, sizeof(buf))) > 0)
         Serial.println(buf);
      file.close();
      Serial.println();
      Serial.print("Finished!");
its works only i pin off a 5v from ethernet module, if turn on a pin 5v from module dont writing.
My sd only works if i change from SPI_HALF_SPEED to SPI_QUARTER_SPEED, and tested with const byte SelectSlave_SD = 5; and const byte SelectSlave_SD = 4; and both works too.
The PINs of the wiring diagram I did this right?
MODULE | ARDUINO
MISO | 50
MOSI | 51
CK | 52
SS | 53
VCC | 5V
GND | GND
Thx
Post Number:#6 Post Thu Aug 06, 2015 6:40 pm
The pinout is ok.
You can't use this value, the comment is very CLEAR.
Are you using 2 power supplies? 1 to W5100 and another to Arduino?
Have you connected the GND of this power supplies?
Post Number:#7 Post Thu Aug 06, 2015 6:54 pm
Topics: 9
Topics: 9
The pinout is ok.
Ok, thx.
all test using a power on USB plug, and Vout 5v or 3v and GND from arduino to module.
This module works on 3v and 5v and tested with both.
Post Number:#8 Post Thu Aug 06, 2015 7:13 pm
Are you using a SD card of 1 or 2 GB?
Post Number:#9 Post Fri Aug 07, 2015 8:05 am
Topics: 9
Topics: 9
Hi, using a 1GB scandisk SD.
follow screens of module and bridge:
Shiel with bridge:
Module:
Post Number:#10 Post Fri Aug 07, 2015 1:27 pm
Look for this:
Apparently you have a short circuit between pin 4 and 53.
Post Number:#11 Post Fri Aug 07, 2015 2:12 pm
Topics: 9
Topics: 9
I verified now, and dont have a short circuit but however climbed over the resistor as you can see in the picture, but still not worked.
Post Number:#12 Post Fri Aug 07, 2015 6:29 pm
Topics: 9
Topics: 9
The bridge on p53 is in a resistor or In a hole after resistor ?
Post Number:#13 Post Fri Aug 07, 2015 7:10 pm
Connect the pin 53 only on W5100.
The bridge is between pin 4 and R16 only.
Post Number:#14 Post Fri Aug 07, 2015 7:27 pm
Topics: 9
Topics: 9
I do not understand, do a test with p53 in module and without the bridge?
Post Number:#15 Post Fri Aug 07, 2015 7:36 pm
The bridge is the "chip select" for SD card no more.
Keep the bridge otherwise will have conflict between SD and W5100 because by default this two devices use the pin 53 to "chip select".
Make sure that haven't short circuit between pin 53 and R16.
Post Number:#16 Post Mon Aug 10, 2015 1:24 pm
Topics: 9
Topics: 9
I get a multimeter for find short circuit between pin 53 and R16 and no have.
Tested tested with only 5v, gnd and Pin53 and ferduino go up normal.
I was testing pin to pin...
and when I called the pin50 in MI connector module the ferduino not started and reappeared on the screen warning SD, if remove pin50 from module a ferduino go up normal.
The pin50 in connector MI in module cause this...
Any idea?
Post Number:#17 Post Mon Aug 10, 2015 2:13 pm
The example "Simple webserver running on SD card" works for you?
Post Number:#18 Post Mon Aug 10, 2015 3:46 pm
Topics: 9
Topics: 9
Tested a code:
#include <SPI.h>
#include <Ethernet.h>
#include <SdFat.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 177); // IP address, may need to change depending on network
EthernetServer server(80);
Sd2Card card;
SdFile file;
SdFile root;
SdVolume volume;
   Serial.begin(9600);
   while (!Serial)
      ; // wait for serial port to connect. Needed for Leonardo only
   Ethernet.begin(mac, ip, SelectSlave_ETH);
   server.begin();
   Serial.print("server is at ");
   Serial.println(Ethernet.localIP());
   Serial.println("Initializing SD card...");
   if (!card.init(SPI_QUARTER_SPEED, SelectSlave_SD))
      Serial.println("ERROR - SD card initialization failed!");
      return;
   volume.init(&card);
   Serial.println("SUCCESS - SD card initialized.");
   if (!file.open(&root, "index.htm", O_READ))
      Serial.println("ERROR - Can't open index.htm file!");
      return;
   file.close();
   Serial.println("SUCCESS - Found index.htm file.");
   EthernetClient client = server.available();
   if (client)
      boolean currentLineIsBlank = true;
      while (client.connected())
         if (client.available())
            char c = client.read();
            if (c == '\n' && currentLineIsBlank)
               client.println("HTTP/1.1 200 OK");
               client.println("Content-Type: text/html");
               client.println("Connection: close");
               client.println();
               if (file.open(&root, "index.htm", O_READ))
                  while(file.available())
                     client.write(file.read());
                  file.close();
               break;
            if (c == '\n')
            else if (c != '\r')
               currentLineIsBlank = false;
      delay(1);
      client.stop();
And save in SD card index.htm this code
// Save this file on SD card as index.htm
<!DOCTYPE html>
<html>
    <head>
        <title>Arduino SD Card Web Page</title>
    </head>
    <body>
        <h1>Hello world! </h1>
      <h2>This page is stored in a SD card plugged on Arduino</h2>
        <p><strong>Visit my website: </strong><a href="http://www.ferduino.com" target="_blank">www.ferduino.com</a> </p>
      <p>Code adapted by Fernando Garcia</p>
    </body>
</html>
Serial monitor
server is at 192.168.0.177
Have too success in ping, but dont can access by browser.
Post Number:#19 Post Mon Aug 10, 2015 4:20 pm
The ping test isn't important.
You need make it work with browser using some example.
What's the IP of your router?
Post Number:#20 Post Mon Aug 10, 2015 4:21 pm
Topics: 9
Topics: 9
My ip is 192.168.0.187/24
My router is 192.168.0.46/24
