Post Number:#201 Post Sat Aug 01, 2015 12:26 am
Post Number:#202 Post Fri Sep 11, 2015 2:31 am
So will be getting back into this project very soon as the new sump for my tank is almost done and, my new board is on it's way, thank you Fernando. :D
Post Number:#203 Post Wed Sep 23, 2015 12:15 am
Post Number:#204 Post Wed Sep 23, 2015 8:15 am
It works for me but I did a clean install.
I'm using IDE from ZIP file for non admin install.
What's the error?
Post Number:#205 Post Wed Sep 23, 2015 8:43 am
Post Number:#206 Post Wed Sep 23, 2015 11:03 pm
Did a fresh install of the IDE now I am getting this error.
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
Feduino_with_webcontrol_CK2.0.ino:75:20: fatal error: Base64.h: No such file or directory
compilation terminated.
Error compiling. :-??
Post Number:#207 Post Wed Sep 23, 2015 11:10 pm
Post Number:#208 Post Wed Sep 23, 2015 11:19 pm
I tried that one and it will not compile. can take the base64.h file to the new IDE?
-------------------------------- Last edited Wed Sep 23, 2015 8:49 pm --------------------------------
went into some older files found one that worked so I am up and running, now it is time to find out what still works. B-)
Post Number:#209 Post Thu Sep 24, 2015 2:35 pm
I must have set everything up right for web control because joy-reef is working for me now too, I will be back on track in no time at all. :D I do have to re calibrate all of my probes and get a new EC stamp though :|
Post Number:#210 Post Sun Sep 27, 2015 11:03 pm
All has been working well for a week now, I do have a question how do you connect the cooling fans for the LEDs? My fans have 3 wires red, black and, yellow. I have looked through many pages and cant seem to find what I am looking for. A fan with 3 pins can only be turned on and off correct?
Last edited by Christopher Kindig on Sun Sep 27, 2015 11:22 pm, edited 1 time in total.
Post Number:#211 Post Sun Sep 27, 2015 11:20 pm
Post Number:#212 Post Sun Sep 27, 2015 11:25 pm
Post Number:#213 Post Sun Sep 27, 2015 11:31 pm
Pin 1, pin 13 (PWM) and GND are available on connector RJ11.
-------------------------------- Last edited Sun Sep 27, 2015 11:37 pm --------------------------------
Don't forget to comment out "Serial.begin(38400) on setup.
Post Number:#214 Post Sun Sep 27, 2015 11:40 pm
pin 1 and 13 are (pwm) control speed, what for just on and off? fans with 3 pins are just on and off not pwm correct.
Post Number:#215 Post Sun Sep 27, 2015 11:43 pm
Pin 1 to disable fan.
Pin 13 to control speed.
const byte desativarFanPin = 1; // Pino que desativa os coolers.
Post Number:#216 Post Sun Sep 27, 2015 11:45 pm
ok I see thank you.
-------------------------------- Last edited Sun Sep 27, 2015 9:11 pm --------------------------------
how do you make the connection to the fan?
Post Number:#217 Post Mon Sep 28, 2015 9:09 am
Using this circuit:
You can add a terminal block to fan, RJ11 to control and a jack to 12V in a small PCB.
Post Number:#218 Post Mon Sep 28, 2015 12:49 pm
On RJ 11 jack pin 1 I have connect 12 power supply in line with fan then the ground goes back to the jack as well?
Post Number:#219 Post Mon Sep 28, 2015 3:54 pm
I don't understand your question.
Maybe it's more clear.
Post Number:#220 Post Tue Sep 29, 2015 9:40 am
I am being very cautious as I do not want to hurt this board, does the 12 volts go in line with the disable pin? As in parallel, or am I seeing that wrong? Then ground goes back the RJ11 jack.
Users viewing this topic: No registered users and 12 guests
