Forum Members section DIY Ferduino controller Connect fans
Connect fans  [SOLVED]
Post Number:#1 Post Sun Oct 04, 2015 6:19 am
Topics: 11
Images: 4
Topics: 11
Hello Fernando. I have to connect two fans arctic f12 4 pin and i don't know if I have to put a ULN2003A to the fans, they are going to operate at the same time. How do I connect the 4 wires that lead the fans?
Post Number:#2 Post Sun Oct 04, 2015 10:50 am
Follow the schematic available here: viewtopic.php?f=24&t=40
Connect the GND from first fan to F1 and the second to F2 and so on.
Post Number:#3 Post Mon Oct 12, 2015 9:26 am
Topics: 11
Images: 4
Topics: 11
Hello Fernando. At the moment it is all resolved, in the absence of the fans. I have fans arctic f12 4 pin pwm and i have put the ULN2003A and the fans connected as you have the schema in the harness: black, yellow, green, and blue. The only problem now is that the fan is always switched on at the same speed and will not turn off what is the solution?
Post Number:#4 Post Mon Oct 12, 2015 10:25 am
The pin 1 (disable) is connected on ULN?
On setup comment this line:
Serial.begin(38400);
Post Number:#5 Post Wed Oct 14, 2015 6:19 pm
Topics: 11
Images: 4
Topics: 11
HAHAHAHA ... I have been testing all over again, before you install it in the aquarium and i see more problems. When the fans are put in place only one works, the other will not move. And the installation as i did this in the diagram.
The ulm is connected to the VIN of the plate because I have it powered with 12V and the GND of the fans are connected to the first pin of the ulm to the first fan, the second pin to the second fan and the blue wire from the fan is connected to pin 13. But I realized that the speed is the same, even though you put more or less speed, stop if they stop but everything else i don't see it well.
Post Number:#6 Post Wed Oct 14, 2015 7:49 pm
If the circuit works with 1 fan should work with 2. Unles pin 1 (disable) from Arduino isn't connected on pin 1 - 7 on ULN2003 as you can see on schematic.
Or your 12V power supply can't give enough current to all devices.
Regarding speed, which temperature you have configured to fans?
Images of your circuit can help but, please post images correctly.
Post Number:#7 Post Sun Oct 18, 2015 5:47 am
Topics: 11
Images: 4
Topics: 11
Hello Fernando. It is resolved at the end was a pin of the ULN that was poorly welded. Thank you very much.
