Forum Members section DIY Ferduino controller Metering pumps
Metering pumps  [SOLVED]
Post Number:#1 Post Sun Jan 17, 2016 6:16 pm
Topics: 8
Images: 10
Topics: 8
Hi Fernando, the dosing pumps are not working, they work in manual mode and also functions to calibrate. In custom mode it makes no dosage.
In the code the variable is boolean dosadoras = true. The memory card has the HDP1.TXT ... HDP6.TXT files.
What can is going on?
Thanks,
Post Number:#2 Post Sun Jan 17, 2016 9:23 pm
Do you have selected all days of week?
What's quantity of doses and volume daily?
What's the content of the file HDP1.TXT?
Post Number:#3 Post Mon Jan 18, 2016 8:28 pm
Topics: 8
Images: 10
Topics: 8
Fernando, is not being nothing recorded on the memory card. After I downloaded the new version is not recording anything on the memory card.
Thanks,
Post Number:#4 Post Mon Jan 18, 2016 9:19 pm
It works with code for test?
Post Number:#5 Post Tue Jan 19, 2016 3:55 pm
Topics: 8
Images: 10
Topics: 8
I tried to install the code tests to create a file on the SD card but does not compile, displays an error:
'SdVolume' does not name the type
I'm not getting tested.
SD Card recording is recorded the LOGDDIA files, LOGODIA, LOGPDIA, LOGRDIA, LOGTDIA.
Thanks,
Post Number:#6 Post Tue Jan 19, 2016 4:04 pm
If this files are on SD card so it's working fine.
Can you see green buttons for days of week and ON/OFF like this?
Post Number:#7 Post Tue Jan 19, 2016 4:08 pm
Topics: 8
Images: 10
Topics: 8
Yes, every day of the week are marked green and the ON / OFF button is ON.
Post Number:#8 Post Tue Jan 19, 2016 4:29 pm
In the tab "dosadoras" go to line 60 find:
      file.close();
Replace with:
        Serial.println(minuto11);
      file.close();
      Serial.println("Can't create the file");
Open the serial monitor and see the result after save the settings.
Post Number:#9 Post Tue Jan 19, 2016 4:39 pm
Topics: 8
Images: 10
Topics: 8
Post Number:#10 Post Tue Jan 19, 2016 4:46 pm
Try format the SD card again.
Can you see the graphs on TFT?
Post Number:#11 Post Tue Jan 19, 2016 5:35 pm
Topics: 8
Images: 10
Topics: 8
Formatted again and continue without saving.
TFT graphics are these?
Thanks,
Post Number:#12 Post Tue Jan 19, 2016 6:01 pm
This:
Try disable ethernet functions, maybe it's conflict.
Post Number:#13 Post Tue Jan 19, 2016 8:54 pm
Topics: 8
Images: 10
Topics: 8
Again I formatted the sd card and now is not recording anything. Does the problem is the sd card?
I will try to look for another card to test.
Thanks,
Post Number:#14 Post Wed Jan 20, 2016 6:38 am
Topics: 8
Images: 10
Topics: 8
I tested with another card and continue without saving the information.
Post Number:#15 Post Wed Jan 20, 2016 11:22 am
Try using this IDE and librairies: https://onedrive.live.com/redir?resid=4 ... file%2crar
Post Number:#16 Post Wed Jan 20, 2016 2:26 pm
Topics: 8
Images: 10
Topics: 8
Friend, still not working. The LOGDDIA files, LOGODIA, LOGPDIA, LOGRDIA, LOGTDIA were created, but not the dosing continues with return "Can't create the file".
I created the HDP1.TXT ... HDP6.TXT files on the memory card and still not save anything.
Post Number:#17 Post Wed Jan 20, 2016 2:30 pm
Can you try with old version of Ferduino code since that it can be a bug in new version?
Post Number:#18 Post Wed Jan 20, 2016 2:58 pm
Topics: 8
Images: 10
Topics: 8
It is a bug in the new version, installed the previous version and files are normally recorded.
Was there any change in the code regarding the metering?
Post Number:#19 Post Wed Jan 20, 2016 3:12 pm
Problems with new version isn't directly related with dosing pumps.
So check if the dosage works with old version. If it doesn't works show me the content of HDP1.TXT.
Post Number:#20 Post Wed Jan 20, 2016 3:19 pm
Topics: 8
Images: 10
Topics: 8
The contents of the file is HDP1.TXT:
0174
0288
0402
0516
0630
0744
0858
0972
1086
1200
It is scheduled as follows:
Start time: 01:00
End time: 22:00
30 ml, 10 doses.
