Forum Members section DIY Ferduino controller Metering pumps
Metering pumps  [SOLVED]
Post Number:#21 Post Wed Jan 20, 2016 3:27 pm
This values are in minutes, so convert to hours and you will know the exact moment to each dosage.
Post Number:#22 Post Wed Jan 20, 2016 3:41 pm
Topics: 8
Images: 10
Topics: 8
You see why this new version is not recording the information on the card?
Post Number:#23 Post Wed Jan 20, 2016 3:47 pm
To each user the code have a different problem. For now I don't know exactly where is the problem.
I know that all functions are working very fine in my controller and I can't replicate this errors here. :(
Post Number:#24 Post Wed Jan 20, 2016 4:20 pm
Topics: 8
Images: 10
Topics: 8
It is a pity. You made any changes in the code from the previous version to the current version concerning metering?
Post Number:#25 Post Wed Jan 20, 2016 4:37 pm
There many changes on code but it isn't the problem because the custom dosage works for me and I know that it works to Danilo Castellano too.
Post Number:#26 Post Wed Jan 20, 2016 5:40 pm
Topics: 8
Images: 10
Topics: 8
So I will not be able to use this new version.I wanted this new version mainly for control of the skimmer that my already spilled about 3 times.
I switched to criar_arquivos function from the previous version, which works with the current version and still does not write the files.
Post Number:#27 Post Wed Jan 20, 2016 10:15 pm
Try the code updated available on Github with IDE 1.6.7.
Post Number:#28 Post Thu Jan 21, 2016 10:28 am
Topics: 8
Images: 10
Topics: 8
This new version'm unable to install, get the white screen. Already changed to UTouch myTouch (6,5,4,3,2);
I do not know what can be.
Post Number:#29 Post Thu Jan 21, 2016 10:50 am
Using the IDE 1.0.6 what happens?
Post Number:#30 Post Thu Jan 21, 2016 2:14 pm
Topics: 8
Images: 10
Topics: 8
Hi, I used the IDE 1.0.6 and installed, but still does not record the dosing information on the card.
Post Number:#31 Post Thu Jan 21, 2016 2:31 pm
On setup try change "HALF_SPEED" to "FULL_SPEED" or "QUARTER_SPEED" to see what happens.
 while (!SD.begin(ChipSelect_SD, SPI_HALF_SPEED))
Post Number:#32 Post Thu Jan 21, 2016 3:00 pm
Topics: 8
Images: 10
Topics: 8
Does not work, does not open, is asking the memory card.
-------------------------------- Last edited Thu Jan 21, 2016 4:22 pm --------------------------------
Fernando, find out what was wrong, the list of SPI devices were selected const byte ChipSelect_SD = 5; It was to be const byte ChipSelect_SD = 4; I commented line 5 and uncommented line 4 and is now recording right.
Such a simple thing and neither he nor you remembered to look.
thank you
Post Number:#33 Post Fri Jan 22, 2016 9:19 am
The dosage is working now?
Post Number:#34 Post Fri Jan 22, 2016 10:58 am
Topics: 8
Images: 10
Topics: 8
Yes, it is now running normal.
Only I'm not using that its latest version, which updated yesterday because here when I installed was restarting.
Thanks,
Post Number:#35 Post Fri Jan 22, 2016 11:46 am
Glad to hear.
I'll close this topic because the initial issue was solved.
