Forum Software Ferduino code RTC problem
RTC problem  [SOLVED]
Post Number:#1 Post Sat Jan 23, 2016 3:38 pm
Belgium
Fernando,
Once again I need your help,since the installation of the last version of Ferduino, I have problem with date and time.
If I try to adjust to correct values, the data are not saved.
I have perform the test code for searching I2C device and the result was 1 device found at 0X20 from what I saw in the forum and in the test code for RTC , it should be 0x68.
In the previous version, it was requested to modify DS1307cpp and Henning H are those modifications still required ?
Could you give me some help
Thanks in advance
Jean-Yves
Post Number:#2 Post Sat Jan 23, 2016 4:46 pm
Your RTC is connected on pins 20 and 21 so change this line on code:
DS1307 rtc(18, 19);
On this case you can't use a PCF8575 without change RTC pins to 18 and 19.
Post Number:#3 Post Sat Jan 23, 2016 4:53 pm
Belgium
Thank you very much, it's OK now but I don't understand because normaly those pins are for Ferduino mega ?
Post Number:#4 Post Sat Jan 23, 2016 5:00 pm
Not exactly, all controllers with PCF8575 should use 18 and 19 to RTC.
Post Number:#5 Post Sat Jan 23, 2016 5:03 pm
Belgium
OK once again thank you for your help and for your work.
Best regards,
Jean-Yves
