Forum Members section LED light and others Power LED
Power LED  [SOLVED]
Post Number:#1 Post Sat Apr 02, 2016 4:10 pm
fernando hello I connected a led strip arduino mega like this photo:
LED strip comes with four cables (green pin 11) (blue pin 9) (red pin 12) and I have 12V power supply connected to the Arduino board and it works but I think it's not right how do you connect? And as you can turn on and off a clock to turn on and off from ferduino?
Post Number:#2 Post Sat Apr 02, 2016 11:24 pm
What's working?
What is not right?
To turn off the LEDs edit the table:
Or edit the preset mode:
Post Number:#3 Post Sun Apr 03, 2016 12:57 pm
ok thanks Fernando think what is not set ferduino do you have any tutorial or instructions for configuration menejo? :-?
Post Number:#4 Post Wed Apr 06, 2016 1:20 pm
In LED table you can select a value to each 15 minutes after choose the interval of 2 hours.
Example:
Select the interval 0 - 2 so the time corresponding to each value is:
00:15, 00:30, 00:45, 01:00, 01:15, 01:30, 01:45 and 02:00
To turn off all LEDs on this interval change all values to 0.
In preset mode you can choose the time for sunset and sunrise to all LEDs.
Too can select a duration to ramp reach the max. PWM.
You can select a PWM to all LEDs or a PWM to each channel.
Post Number:#5 Post Wed Apr 06, 2016 7:24 pm
ok Fernando working perfect thanks again
Users viewing this topic: No registered users and 5 guests
