I am using your code in a diy controller with no lcd and have a few questions please.
1) what is the best way to connect 1 PH stamp on its own and do I need to change any code?
2) when its turned on, it slowly comes up to te correct led brightness then after about 30 seconds to 1 minute, all the leds turn off then it slowly comes back up to full brightness and keeps doing this over and over. have you any suggesions please? I have the pwm wires and gnd connected to an ldd 5up boards with ldd-h drivers on it. I dont think its anything to do with the drivers though as everytime the leds go off, it ramps back up to full power which is a controller feature.
3) i am only using 3 of the outlets, can I put the 5 timers in the others place without changing too much code? otherwise can I set the timers to be on all the time?
4) on led presets, if i set red to 100 and uv to 200 then save, then refresh the screen, the values are swaped round? this is all done from the web interface as I have no LCD connected.
Any help is appreciated
