Forum Software Ferduino code Error when trying to load code
Error when trying to load code  [SOLVED]
Post Number:#1 Post Sat Jun 07, 2014 10:14 pm
Topics: 5
Topics: 5
Canada
Fernando
I get the following error code when I try to upload the Freduino with Web Control
variable or field 'write CRLF' declared void
and this line of code is highlighted orange const byte solenoide1Pin = 85; // P5 // Connects to spare freshwater.
I have tried reloading the libraries as instructed in the forum but still no change I know I must have missed a step somewhere but I don't know where to start.
Thank You
Donato
Post Number:#2 Post Sun Jun 08, 2014 9:46 am
You checked others topics here?
This by example: viewtopic.php?f=8&t=44
Have a print screen of the error?
Post Number:#3 Post Sun Jun 08, 2014 6:03 pm
Topics: 5
Topics: 5
Canada
Fernando I see some of the files are missing in the library
I now assume I need to use the libraries from the original Ferduino code and add well as the new ones to the 1.0.5-r2 library folder ?
Regards
Donato
Post Number:#4 Post Sun Jun 08, 2014 6:09 pm
Regards
Donato
Exactly.
Post Number:#5 Post Sun Jun 08, 2014 6:15 pm
Topics: 5
Topics: 5
Canada
Fernando
I still seem to have one file different
I have DS1307 but in your response to Sueur Aurelien in this post viewtopic.php?f=8&t=44
the third image shows DS1307henning do I need to change it and where do I get that file.
Thank You
Donato
Post Number:#6 Post Sun Jun 08, 2014 6:17 pm
Watch this video please.
video.php?mode=view&id=3
Post Number:#7 Post Sun Jun 08, 2014 6:43 pm
Topics: 5
Topics: 5
Canada
Fernando
Problem solved and sketch compiled properly.
There is a problem with the English version of DS1307 File
I even tried renaming it but that did not work.
I grabbed the file from the Portuguese version 'DS1307henning' and added it to the Arduino IDE libraries Folder
and it worked.
Regards
Donato
Post Number:#8 Post Sun Jun 08, 2014 10:00 pm
The library downloaded with "Ferduino_English" is in english.
To use the Ferduino with web control you need change only this line:
https://github.com/FernandoGarcia/Fedui ... ta.ino#L65
#include <DS1307.h>
Post Number:#9 Post Sun Jun 08, 2014 11:55 pm
Topics: 5
Topics: 5
Canada
Fernando
I tried changing line 65 to
#include <DS1307.h>
and put DS1307 file from 'Ferduino English master' back into libraries of 1.0.5-r2 but the code would not compile
I'll also noticed that even though the method I used earlier allowed me to load the code onto the mega the time is not updating and I cannot change date or time.
Thank You for your help
Donato
Post Number:#10 Post Mon Jun 09, 2014 12:07 am
You can give me a print screen of the error?
What model of RTC you have?
Post Number:#11 Post Mon Jun 09, 2014 12:46 am
Topics: 5
Topics: 5
Canada
I hope the image worked if not I can email it to you
the error is on line169 of code and it says
'DS1307" does not name a type
I am using the TFT shield ITDB02 with the built in RTC
Regards
Donato
Last edited by Fernando Garcia on Mon Jun 09, 2014 7:51 am, edited 1 time in total.
Reason: Image fixed.
Post Number:#12 Post Mon Jun 09, 2014 7:55 am
You used the link wrong.
Use the "direct link" on Photobucket.
You have this library in the libraries folder?
https://github.com/FernandoGarcia/Ferdu ... cas/DS1307
How many libraries "DS1307" you have in the libraries folder?
Post Number:#13 Post Mon Jun 09, 2014 11:10 pm
Topics: 5
Topics: 5
Canada
Fernando
It appears to be the correct version of DS1307 but I will have to take a closer look.
I also still seem to have a problem with the RTC. I used the test code that you posted in the forum and it installed
fine but it will not accept time and date changes. I will have to double check my solder joints, it may also be a failed component.
I am also going to be woking long days for the next 2 weeks so I have to be patient and take my time, I may not be able to respond
right away.
Thank You for all your help and time Fernando
Regards
Donato
Post Number:#14 Post Wed Jun 11, 2014 10:50 pm
Topics: 5
Topics: 5
Canada
Fernando
I must have had a bad download or computer issue.
I did a fresh install on a different computer and
and edited the line like you instructed and it installed properly without issue. :-bd
Now I just have to work out the RTC issue which is either a bad component or bad soldering connection.
Thank you for all your help
Regards
Donato
Post Number:#15 Post Sat Jun 14, 2014 6:57 pm
Please mark this topic as solved.
Post Number:#16 Post Sun Jun 15, 2014 1:43 pm
Topics: 5
Topics: 5
Canada
Will do Fernando
I also solved my RTC issue by using a IC2 scanner to find the IC2 address, it was very simple and easy.
For anyone who needs it it can be found here
http://projectsfromtech.blogspot.ca/201 ... duino.html
The example shown is for a Tiny RTC DS1307 but it shoulld work for any IC2 device.
Thanks again and now on to more testing!
Regards
Donato
