Forum Software Ferduino code Error when compiling code
Error when compiling code  [SOLVED]
Post Number:#1 Post Fri Jun 13, 2014 7:14 pm
Len Nederlof Random avatar
Hello when i try to compile the ferduino with web control code i get the following error.
Feduino_with_webcontrol_beta:867: error: 'A15' was not declared in this scope
Setup.ino: In function 'void setup()':
Setup:5: error: 'Serial3' was not declared in this scope
Stamps.ino: In function 'void parametros()':
Stamps:7: error: 'Serial3' was not declared in this scope
Stamps:39: error: 'Serial3' was not declared in this scope
Stamps:71: error: 'Serial3' was not declared in this scope
Stamps.ino: In function 'void iniciar_stamps()':
Stamps:121: error: 'Serial3' was not declared in this scope
Stamps.ino: In function 'void Open_channel(short int)':
Stamps:194: error: 'Serial3' was not declared in this scope
It also happens when use the original sketch from the download (not changing the language and ethernet settings)
Kind regards Len
Post Number:#2 Post Fri Jun 13, 2014 8:01 pm
Hi Len Nederlof :-h
You do not have to look for similar topics posted before : http://www.ferduino.com/forum/viewtopic.php?f=8&t=44
have you watch this http://www.ferduino.com/forum/viewtopic.php?f=8&t=18 for install Ferduino code.
Well you have to delete the old libraries before copying the library in the directory arduino Ferduino your pc?
Post Number:#3 Post Fri Jun 13, 2014 9:04 pm
This error is typical of bad configuration in the IDE.
Go to tools > board > select the arduino mega 2560
Post Number:#4 Post Sun Jun 15, 2014 5:49 am
Thanks for your answer, that was the solution. I think that something has changed it from arduino mega to arduino uno.I did not noticed that.
Len
