Forum Software Ferduino code Ethernet
Ethernet
Post Number:#1 Post Sat Jun 14, 2014 3:07 pm
hello once the ethernet module is soldered must change something in the Arduino code?
I pence yes to this page after
http://ferduino.com/forum/viewtopic.php?f=8&t=34
But I do not understand how or or
If a person wants to m cordially helped (I'm not talking about the routing parties) just next arduino
Post Number:#2 Post Sat Jun 14, 2014 3:17 pm
Welcome Jeremy!
Please, specify better your problem.
This topic have all changes necessary.
Post Number:#3 Post Sat Jun 14, 2014 3:20 pm
Post Number:#4 Post Sat Jun 14, 2014 3:32 pm
What you want mean?
All details are on topic that you indicated.
What code you want use?
Post Number:#5 Post Sat Jun 14, 2014 3:42 pm
Post Number:#6 Post Sat Jun 14, 2014 3:45 pm
You saw this?
In Ferduino tab find:
If you want use an ethernet shield W5100, go to setup tab.
Post Number:#7 Post Sat Jun 14, 2014 3:48 pm
Post Number:#8 Post Sat Jun 14, 2014 3:56 pm
Sorry, check the topic again and look the code.
You need change only the Ferduino tab.
Post Number:#9 Post Sat Jun 14, 2014 4:12 pm
error
Ferduino_French:435: error: 'UIPEthernet' is not a class or namespace
Ferduino_French:435: error: conflicting declaration 'byte buffer [500]'
Ferduino_French:69: error: 'buffer' has a previous declaration as 'char buffer [50]'
Setup.ino: In function 'void setup()':
Setup:87: error: 'UIPEthernet' is not a class or namespace
Post Number:#10 Post Sat Jun 14, 2014 6:00 pm
Post Number:#11 Post Sat Jun 14, 2014 6:16 pm
Post Number:#12 Post Mon Jun 16, 2014 5:27 am
Hi! Here the retracted configuration in the arduino code
char *credencial = "jeremy:******"; // Coloque aqui seu usuário e senha cadastrados no http://www.joy-reef.com. Usuário e senha devem estar separados por dois pontos (:);
                                              // Use apena letras minúsculas.
byte maxima_tentativa = 3; // Número máximo de tentativas de autenticação.
unsigned long intervalo_tentativa = 15; // Tempo  de espera (em minutos) para novas tentativas.
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Este MAC deve ser único na sua rede local.
byte ip[] = {192,168,1,21}; // Configure o IP conforme a sua rede local.
IPAddress gateway(192,168,1,254); // Configure o "Gateway" conforme a sua rede local.
IPAddress subnet(255, 255, 255, 0); // Configure a máscara de rede conforme a sua rede local.
EthernetServer server(21);// Coloque aqui o número da porta configurada no seu roteador para redirecionamento.
                          // O número da porta deverá ser obrigatóriamente um destes: 21, 25, 53, 80, 110, 143 ou 443
I've always the connection error
Last edited by Fernando Garcia on Mon Jun 16, 2014 9:52 am, edited 1 time in total.
Reason: Password removed.
Post Number:#13 Post Mon Jun 16, 2014 5:40 am
Hi jeremy.
I had the same problem at home.
i tried lot of thing, but nothing works
i established all parameters by default on Ferduino ip address 192.168.0.177 gateway 192.168.0.1 and i modified my router (freebox) to this address (192.168.0.1)and now it works.
But why ??? i don't know
Post Number:#14 Post Mon Jun 16, 2014 6:17 am
Post Number:#15 Post Mon Jun 16, 2014 8:27 am
Firstly, no put personal information here.
Always use this tag to post a code.
viewtopic.php?f=8&t=32
This is wrong.
I told to use ONLY numbers on password.
You need configure the password on Joyreef also.
Look this topic to see how test with local IP.
viewtopic.php?p=335#p335
