Forum Software Ferduino code RTC DS3231 don't work
RTC DS3231 don't work  [SOLVED]
Post Number:#1 Post Sun Jun 24, 2018 6:31 pm
Topics: 9
Topics: 9
I installed the RTC DS3231 without EEPROM module, together with the TFT shield mega shield v2.2, but it is not recognized by Ferduino, I have already used the I2C and RTC test codes, and none of them recognize the RTC module. I've tried replacing the Arduino via USB and external 9V and 12V sources, but it's still the same.
When I try to set the date by Ferduino, the date always returns to Sunday 0, 2000, even after saving the current date.
I also tested the DS3231 battery and it is normal voltage, I have already tested all the pins and soldering done and everything is normal.
I used pins 18 and 19 for connection as explained in this link: https://www.ferduino.com/forum/viewtopic.php?f=24&t=488
Note: I do not want to use pins 20 and 21 because I intend to use the PCF8575.
I'm lost, I do not know what else to do.
Post Number:#2 Post Sun Jun 24, 2018 6:43 pm
Just for test connect the module to pins 20 and 21 then use the test code i2c scan to see if the controller can find the module.
The address should be 0x68.
If can't find the module can be bad or the wiring is wrong.
Post Number:#3 Post Mon Jun 25, 2018 8:30 pm
Topics: 9
Topics: 9
I changed the pins of the RTC to 20 and 21 and it worked. But I will need to use PCF8575, how do I get to use the PCF8575 without using pins 20 and 21?
Another question, is it not necessary to swap the Henning DS1307 RTC library for DS3231?
Rômulo.
Post Number:#4 Post Mon Jun 25, 2018 8:39 pm
Just connect the RTC to pins 18 and 19 then select the pins on code.
