Forum Members section DIY Ferduino controller Tilt hydrometer
Tilt hydrometer  [SOLVED]
Post Number:#1 Post Thu Dec 13, 2018 4:48 am
Images: 5
Hello Fernando,
Thanks for the quickly reply!
Looking the code I saw that a tilt hydrometer can also be used in place of the conductivity stamp.
Could you tell me which hydrometer you speak?
Post Number:#2 Post Thu Dec 13, 2018 8:45 am
The device is called iSpindel was created by Samuel Lang.
The device is used in home brew but can be used on reef tank if do you have a quiet place on sump because the device can't be shaking all time.
The device should be a good alternative to measure the water density in a saltwater mix station.
I did a simplified version of iSpindel using the ESP-WROOM-02 Motherboard but it's spending so much battery so I have to make some changes. For this reason I haven't published a tutorial yet.
The modified code to work with Ferduino is here: https://github.com/FernandoGarcia/iSpin ... -MQTT-only
You can find more information about this device here:
https://hobbybrauer.de/forum/viewtopic.php?f=58&t=11826
https://www.homebrewtalk.com/forum/thre ... er.598187/
