ESP8266  [SOLVED]
Post Number:#1 Post Sun May 02, 2021 2:02 pm
Images: 1
Hello I am in esp8266 12f .. esp link works well it and well connected to ferduino. Com in the ferduino code I must entered ip 'Mac. Gw ...?
Post Number:#2 Post Sun May 02, 2021 3:37 pm
No, just uncomment this line:
// #define USE_ESP8266
After install the code open the serial monitor and set the baud rate to 38400 then check if ESP and Arduino are synced.
Post Number:#3 Post Mon May 03, 2021 6:19 am
Images: 1
Hello the serial monitor...
There will be clouds today
There will be lightning today
Cloud schedule(0:0. 0:0.)
Cloud duration 9 minute
Lightning duration 5 minute
Free memory :4805
-------------------------------- Last edited Mon May 03, 2021 6:31 am --------------------------------
After that, there is no probe and no lighting connected to my arduino, can it be?
Post Number:#4 Post Mon May 03, 2021 8:18 am
You have to leave the code in this way:
#define ETHERNET_SHIELD
#define USE_ESP8266
Then look for this message on serial monitor:
Syncing Arduino and ESP8266...
Synced!
Or
Syncy failed!!
Is not needed connect probes to controller.
Post Number:#5 Post Mon May 03, 2021 3:00 pm
Images: 1
#define USE_ESP8266
Synced!
Or
Syncy failed!!
Thank you fernando for answering me I will review my connection diagram for Converter Bi-Directional Module 5V to 3.3V Arduino I ordered Experiment board I am coming back to tell you if it works
Salutations
Post Number:#6 Post Mon May 03, 2021 4:48 pm
What's the reason to use ESP8266 12F instead NodeMCU? Are you doing a custom board?
The "experiment board" you are talking about is like this?
Post Number:#7 Post Mon May 03, 2021 5:27 pm
Images: 1
Image: https://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=744
I thought that the nodemcu were the same as esp8266 12f for the plate experience
Last edited by Fernando Garcia on Tue May 04, 2021 10:11 am, edited 1 time in total.
Reason: Please post images using tags [img=left]URL[/img].
Post Number:#8 Post Tue May 04, 2021 10:21 am
ESP8266 12F is the microcontroller used on NodeMCU.
This "experience plate" is more known as breadboard or protoboard. ;)
Post Number:#9 Post Tue May 04, 2021 3:17 pm
Images: 1
Thank you, Fernando, I learned something
Salutations
Post Number:#10 Post Sat May 08, 2021 9:44 am
Images: 1
Salutations
Hi fernando after reviewing my arduino nodemcu connection all function wonderfully thank you very much and great your workp
Post Number:#11 Post Sat May 08, 2021 7:35 pm
Users viewing this topic: SEMrush [Bot] and 1 guest
