Forum Software Ferduino code How add two more PCF8575 to the Ferduino Code
How add two more PCF8575 to the Ferduino Code  [SOLVED]
Post Number:#1 Post Sat Aug 30, 2014 9:50 am
Hello every people, I have to add two more PCF8575 to the Ferduino code because I modify for my own requirements.
Can anyone help my?
Post Number:#2 Post Sat Aug 30, 2014 10:36 am
Follow this example.
I remember that I explained it for you on Portalpez.
Anyway I'll put an example here.
#include <PCF8575.h>
byte address_1 = xxxx; // Change this address
byte address_2 = xxxx; // Change this address
byte address_3 = xxxx; // Change this address
PCF8575 PCF8575_1; // First PCF
PCF8575 PCF8575_2; // Second PCF
PCF8575 PCF8575_3; // Third PCF
  PCF8575_1.begin(address_1);
  PCF8575_2.begin(address_2);
  PCF8575_3.begin(address_3);
  for(int i = 0; i < 16; i++)
    PCF8575_1.pinMode(i, OUTPUT);
    PCF8575_2.pinMode(i, OUTPUT);
    PCF8575_3.pinMode(i, OUTPUT);
    PCF8575_1.digitalWrite(i, HIGH);
    PCF8575_2.digitalWrite(i, HIGH);
    PCF8575_3.digitalWrite(i, HIGH);
    delay(1000);
    PCF8575_1.digitalWrite(i, LOW);
    PCF8575_2.digitalWrite(i, LOW);
    PCF8575_3.digitalWrite(i, LOW);
    delay(1000);
Change the address of each IC connecting A0-A2 to 5V or GND.
Use the example available here to scan addresses.
Post Number:#3 Post Sat Aug 30, 2014 10:43 am
Hi Fernando, sorry too much, but I don't find it in Portalpez.
Thanks to much.
Post Number:#4 Post Sat Aug 30, 2014 10:49 am
See this.
Post Number:#5 Post Sat Aug 30, 2014 11:27 am
Hi Fernando, I search it page by page of the post controller of arduino.
Thanks for show it.
Post Number:#6 Post Sat Aug 30, 2014 3:23 pm
Hi Fernando, excuse me for ask too much, but it's my two last questions:
Frist: If I put in this way the 36 heaters:
const int aquecedor1Pin =  // Pino que liga o aquecedor
const int aquecedor2Pin =
const int aquecedor3Pin =
const int aquecedor4Pin =
const int aquecedor5Pin =
const int aquecedor6Pin =
const int aquecedor7Pin =
const int aquecedor8Pin =
const int aquecedor9Pin =
const int aquecedor10Pin =
const int aquecedor11Pin =
const int aquecedor12Pin =
const int aquecedor13Pin =
const int aquecedor14Pin =
const int aquecedor15Pin =
const int aquecedor16Pin =
const int aquecedor17Pin =
const int aquecedor18Pin =
const int aquecedor19Pin =
const int aquecedor20Pin =
const int aquecedor21Pin =
const int aquecedor22Pin =
const int aquecedor23Pin =
const int aquecedor24Pin =
const int aquecedor25Pin =
const int aquecedor26Pin =
const int aquecedor27Pin =
const int aquecedor28Pin =
const int aquecedor29Pin =
const int aquecedor30Pin =
const int aquecedor31Pin =
const int aquecedor32Pin =
const int aquecedor33Pin =
const int aquecedor34Pin =
const int aquecedor35Pin =
const int aquecedor36Pin =
How can I name the pins of for these heaters? for example:
const int aquecedor1Pin = PCF8575_1.pin1
Second: I have other error in the void mainScreen, I put here the code that I modify for you check, if you please :x .
I don't know, please help me
Post Number:#7 Post Sat Aug 30, 2014 4:05 pm
This is explained on Portalpez as I told before.
const int aquecedor1Pin = 0; // First PCF8575
const int aquecedor2Pin = 1;
const int aquecedor17Pin = 0; // Second PCF8575
const int aquecedor18Pin = 1;
And so on.
The support to this version was abandoned.
Post Number:#8 Post Sat Aug 30, 2014 6:28 pm
Hello fernando, sorry too much for ask about a old version, relly, sorry too much, but I have a last question, I promise that I don't ask any more ^:)^ .
I have this error:
Leds.ino: In function 'void mainScreen(boolean)':
Leds:3: error: a function-definition is not allowed here before '{' token
Tempo_e_data:92: error: expected `}' at end of input
Thanks too much and sorry.
Post Number:#9 Post Sat Aug 30, 2014 10:52 pm
This topic is about PCF8575.
This problem is related with PCF8575?
My suggestion for you is: Buy a TFT 400 x 240 and use a version available here.
Hi Fernando, I resolve this problem jet, only need a "}" in a part of teh code, If you want, I put it here to download for you or everyone.
