Forum Software Ferduino code Wavemake
Wavemake  [SOLVED]
Post Number:#1 Post Sat Sep 13, 2014 6:29 pm
Topics: 22
Topics: 22
hi
you can change the way one of the wavemaker so that the minimum power is 30% and not 0%?
make from 30% to 100%
Post Number:#2 Post Sun Sep 14, 2014 3:12 pm
Welcome Simone!
In the tab "wavemaker" find:
  if(modo_selecionado == 1)
    value = int(128 + 127 * sin(2  *  PI / periodo * times));
    Pump1PWM = 255 - value;
    Pump2PWM = value;
Add after:
    Pump1PWM = map(Pump1PWM, 0, 255, 77, 255);
    Pump2PWM = map(Pump2PWM, 0, 255, 77, 255);
Find:
  else if(modo_selecionado == 2)
Add after:
 value = map(value, 0, 255, 77, 255);
Find:
Pump1PWM += 50;
Replace with:
Pump1PWM += 77;
Find:
Pump2PWM += 50;
Replace with:
Pump2PWM += 77;
The mode 3 never will be smaller than 50%.
Post Number:#3 Post Mon Sep 15, 2014 3:43 pm
Topics: 22
Topics: 22
thank you very nice
I try with these changes that I've listed
I ask you one other thing
You can insert a pause button to put the pumps during the meal to the fish?
thanks
Post Number:#4 Post Mon Sep 15, 2014 4:22 pm
Try this:
Add in ferduino tab:
unsigned long interval_feed_millis = 0;
int interval_feed = 10; // in minutes
boolean feed_mode = false;
Add on loop:
if(feed_mode == true)
  if((millis() - interval_feed_millis) > (interval_feed*60000))
    feed_mode = false;
in ProcessyMyTouch find:
    case 0:                       //Tela de inico
      dispScreen=30;
      clearScreen();
      solicitar_senha();
      break;
Replace with:
      if(((x > 0)  &&  (x < 399)  &&  (y > 0)  &&  (y < 138)) || ((x > 128) && (x < 399) && (y >= 138) && (y < 239)))
        dispScreen=30;
        clearScreen();
        solicitar_senha();
        break;
        feed_mode = true;
        interval_feed_millis = millis();
in "wavemaker" find:
  analogWrite(wavemaker1, Pump1PWM);
  analogWrite(wavemaker2, Pump2PWM);
Replace with:
    analogWrite(wavemaker1, 0);
    analogWrite(wavemaker2, 0);
Post Number:#5 Post Mon Sep 15, 2014 5:30 pm
Topics: 22
Topics: 22
I have the break in WaveMaker night at that point as I change to have both?
here is what I
if ((bled_out == 0) && (wled_out == 0) && (rbled_out == 0) && (rled_out == 0) && (uvled_out == 0))
    analogWrite (wavemaker1, int (Pump1PWM * 0.3));
  analogWrite (wavemaker2, int (Pump2PWM * 0.3));
    analogWrite (wavemaker1, int (Pump1PWM * 0.8));
  analogWrite (wavemaker2, int (Pump2PWM * 0.8));
Last edited by Fernando Garcia on Mon Sep 15, 2014 9:07 pm, edited 2 times in total.
Reason: Added tag to code
Post Number:#6 Post Mon Sep 15, 2014 6:10 pm
Please, use the tags below to post any code on forum.
Post Number:#7 Post Mon Sep 15, 2014 7:05 pm
Topics: 22
Topics: 22
by an error in the compilation:
Webserver.ino: In function 'void Wavemaker()':
Webserver:2: error: a function-definition is not allowed here before '{' token
Webserver:588: error: expected `}' at end of input
Post Number:#8 Post Mon Sep 15, 2014 9:16 pm
My code haven't any error.
Check your changes.
Post Number:#9 Post Tue Sep 16, 2014 4:02 pm
Topics: 22
Topics: 22
ok thanks I was able to correct
but I do not understand how to put the pumps break to feed the fish
thanks
Post Number:#10 Post Tue Sep 16, 2014 5:02 pm
Simple!
Touch the area marked in red in the image above.
Post Number:#11 Post Tue Sep 16, 2014 6:29 pm
Topics: 22
Topics: 22
ok thanks it works fine
Sight is not possible to create a button on the menu 2? labeled food
thanks
because with the Italian written some words are cut? example
RISCALDATORE I see him cut RISCALDATO
thanks
Post Number:#12 Post Tue Sep 16, 2014 6:48 pm
All is possible.
I'll not make it for you.
Try learn a bit.
The problem with texts is to other topic.
