Forum Software Ferduino code SD Files
SD Files  [SOLVED]
Post Number:#1 Post Thu Oct 02, 2014 10:14 pm
Is there a way to access the files on the micro SD card on the Ethernet card with out having to take the stack apart ??
Post Number:#2 Post Fri Oct 03, 2014 10:43 am
Use this code:
#include <SdFat.h>
const int chipSelect = 5;     // For Ferduino Mega 2560
//const int chipSelect = 4;   // For ethernet shield
Sd2Card card;
SdFile file;
SdFile root;
SdVolume volume;
char *arquivo[11] = {"LOGTDIA.TXT", "LOGPDIA.TXT", "LOGODIA.TXT", "LOGDDIA.TXT", "LOGRDIA.TXT", "HDP1.TXT", "HDP2.TXT", "HDP3.TXT", "HDP4.TXT", "HDP5.TXT", "HDP6.TXT"};
  int data;
  Serial.begin(9600);
  card.init(SPI_QUARTER_SPEED, chipSelect);
  volume.init(&card);
  root.openRoot(&volume);
  while(!Serial)
    ; // wait for serial.
  for(int i = 0; i < 11; i++)
    if(file.open(&root, arquivo[i], O_READ))
      Serial.print("Reading ");
      Serial.print(arquivo[i]);
      Serial.println(" ...");
      Serial.println("*******************************");
      delay(2000);
      while ((data = file.read()) >= 0)
         Serial.write(data);
      file.close();
      Serial.println("Finished!");
      Serial.println("******************************");
      Serial.println();
      Serial.print("Can't open ");
      Serial.println(" !");
      Serial.println();
      delay(2000);
Post Number:#3 Post Sat Oct 04, 2014 12:16 am
is there a way to use that sketch with out clearing the eeprom that is running the Ferduino sketch on it now?? I am not even sure if I am logging all the different things I am suppose to will have to look in to it more over this weekend
Post Number:#4 Post Sat Oct 04, 2014 11:30 am
What's the a reason to clear the EEPROM after use a code that no changes any value saved?
You can see some "#include <EEPROM.h>" or "EEPROM.write()" on code?
Post Number:#5 Post Sun Oct 05, 2014 12:04 am
no I do not see any "#include <EEPROM.h>" or "EEPROM.write()" just don't understand how to use this code with out deleting what I have on the arduino now then uploading that new code use it then EEPROM.clear then reupload the Ferduino code if there is a better way then please teach me so other users will read it and be able to benefit.
Post Number:#6 Post Sun Oct 05, 2014 10:09 am
The answer is simple.
You NEVER need clear the EEPROM after use any code that no changes the values saved.
Post Number:#7 Post Mon Oct 06, 2014 12:28 am
worked out very well for me all the files are there just the last 6 could not be open
Thank you for teaching me this
