Forum Software Ferduino code Temperature and locks wavemaker
Temperature and locks wavemaker  [SOLVED]
Post Number:#1 Post Sun Oct 05, 2014 7:31 am
Topics: 22
Topics: 22
I noticed that when I connect the temperature probes the wavemaker mode 1 has the block about every 5 seconds pretty obvious
can be improved so that everything is more linear?
thanks
Post Number:#2 Post Sun Oct 05, 2014 10:16 am
This is not a problem.
The Atmega isn't multitask so when you see a small pause on graphs it mean that the controller is doing others things.
Post Number:#3 Post Sun Oct 05, 2014 4:40 pm
Topics: 22
Topics: 22
thanks
I can set the reading parameters from 5 seconds to 10 seconds?
there are problems?
Post Number:#4 Post Mon Oct 06, 2014 10:40 am
On loop find:
if (millis() - previousMillis > 5000)
Replace with:
if (millis() - previousMillis > 10000)
In the tab "parametros" find:
  if(contador_temp == 12)
    tempC = temperatura_agua_temp / 12;
    tempH = temperatura_dissipador_temp / 12;
    tempA = temperatura_ambiente_temp / 12;
Replace with:
  if(contador_temp == 6)
    tempC = temperatura_agua_temp / 6;
    tempH = temperatura_dissipador_temp / 6;
    tempA = temperatura_ambiente_temp / 6;
Post Number:#5 Post Mon Oct 06, 2014 5:03 pm
Topics: 22
Topics: 22
thanks
I know why I have to change this code also ?????????
in this
Post Number:#6 Post Mon Oct 06, 2014 5:21 pm
Because 60 seconds / 10 seconds = 6, so the temperature will be updated to each 60 seconds.
Otherwise 12 * 10 seconds = 120 seconds, of this way the temperature will be updated to each 120 seconds.
Post Number:#7 Post Tue Oct 07, 2014 8:59 am
Topics: 22
Topics: 22
thanks
but I do not understand
with 5 seconds was 12
I have to put with 10 seconds to 6
Post Number:#8 Post Tue Oct 07, 2014 9:59 am
12 * 5 = 60 seconds.
Only ask is very easy.
Look the code and try learn.
void checkTempC()
contador_temp ++;
sensors.requestTemperatures(); // Chamada para todos os sensores.
temperatura_agua_temp += (sensors.getTempC(sensor_agua)); // Lê temperatura da água
temperatura_dissipador_temp += (sensors.getTempC(sensor_dissipador)); // Lê temperatura do dissipador
temperatura_ambiente_temp += (sensors.getTempC(sensor_ambiente)); // Lê temperatura do dissipador
contador_temp = 0;
temperatura_agua_temp = 0;
temperatura_dissipador_temp = 0;
temperatura_ambiente_temp = 0;
