Forum Members section DIY Ferduino controller Touch problem
Touch problem  [SOLVED]
Post Number:#1 Post Wed Oct 22, 2014 1:31 pm
Hi
I need your help.
I installed all the components. I made the calibration but the coordinates are only the same, also I don't touch the "+" .
The coordinate are Always the following:
CAL_X 0x4000BFFFUL
CAL_Y 0x4000BFFFUL
CAL_S 0x000EF18FUL
I changed the coordinates in the UtouchCD file but if i touch the LCD nothing to do. Can you help me?
thank you
Post Number:#2 Post Wed Oct 22, 2014 1:38 pm
Welcome Enrico!
What you mean with it?
Check this topic.
Post Number:#3 Post Wed Oct 22, 2014 2:03 pm
means that if I touch the screen, even not in the exact spot, but in any part, the coordinates do not change but are the same
Post Number:#4 Post Wed Oct 22, 2014 4:35 pm
You tried the coordinates available on topic above?
Post Number:#5 Post Thu Oct 23, 2014 3:00 am
Yes Fernando, i think that the problem is another, if i touch the lcd in many point always different and the coordinate that i can read are always the same......is it possibile that the shield is demaged? How i can test it?
Thank you very much for you attentions
Post Number:#6 Post Thu Oct 23, 2014 4:46 pm
Check if the pins 2 - 6 are connected fine.
Post Number:#7 Post Fri Oct 24, 2014 6:00 pm
Nothing to do. Pin 2-6 are ok but I have the some problem!
Post Number:#8 Post Sat Oct 25, 2014 12:58 pm
Solved
Code:
#define CAL_X 0x00430ED8UL
#define CAL_Y 0x002A0EECUL
#define CAL_S 0x000EF18FUL
and then in the code file FERDUINO in file ProcessMyTouch change the code:
Code:
x=myTouch.getX ();
y=myTouch.getY ();
on
Code:
x = 399-myTouch.getX ();
y = 239-myTouch.getY ();
Thank you very much
