ESP8266
Post Number:#41 Post Mon May 11, 2020 8:47 pm
Images: 11
Turkey
arrow. I never forget these again. By the way can I fade something. I want to get information about Ferduino Motherboard. I want to use the fee. I would like to know technical. You can expand your projects in Turkey because I have made a very large group. How do you say. In Turkey, I will do my best to announce this motherboard.
Post Number:#42 Post Mon May 11, 2020 8:54 pm
Images: 280
Solve rating: 219
Not sure. The problem was solved?
Unfortunately I haven't money to make boards. I lost all my money of this project to a chinese manufacturer.
Thanks anyway.
Post Number:#43 Post Mon May 11, 2020 9:01 pm
Images: 11
Turkey
Serial gave the same text on the monitor. The problem has not changed.
-------------------------------- Last edited Mon May 11, 2020 9:03 pm --------------------------------
What matters is not money. If the function of the motherboard is good, money is solved. It is difficult to do business with the Chinese. Because they worship them money.
-------------------------------- Last edited Mon May 11, 2020 9:08 pm --------------------------------
I'm very sorry for you. You can still send me a guide document explaining all the features of the motherboard.
-------------------------------- Last edited Mon May 11, 2020 9:10 pm --------------------------------
The problem persists.
Post Number:#44 Post Mon May 11, 2020 9:25 pm
Images: 280
Solve rating: 219
All information about Ferduino Mega 2560 is here.
In this point I can't guide you step by step. You have to search for solutions on Google since this is not a problem with Ferduino code.
Try install an example like this using Arduino IDE.
If examples are working so try install ESP-link again.
Also you can try the latest version of ESP-link from here.
If the magic error remains so try search a solution like this in ESP8266 repository.
Otherwise you should buy another NodeMCU.
Moreover you should test the NodeMCU alone just connected to USB to make sure this is not a wiring error.
Post Number:#45 Post Thu May 14, 2020 8:17 pm
Images: 11
Turkey
I bought the esp8266 card. I'll do it if you discard the connection diagram of this card. I want to try what you taught me on this. The only problem is the connection diagram image. Arduino2560 + Esp8266. Thank you.
Post Number:#46 Post Thu May 14, 2020 8:26 pm
Images: 280
Solve rating: 219
If do you want you should buy another NodeMCU. I won't give support for another model of ESP8266.
I'm recommending NodeMCU because it's very simple to set up.
Post Number:#47 Post Fri May 15, 2020 3:01 pm
Images: 11
Turkey
Hi
Okay I should get another NodemCu. Thanks for your help.
-------------------------------- Last edited Fri May 15, 2020 3:11 pm --------------------------------
1-
2-
Which one should I take? Can you say 1 or 2? .Thank you
Last edited by Fernando Garcia on Fri May 15, 2020 4:06 pm, edited 1 time in total.
Post Number:#48 Post Fri May 15, 2020 4:07 pm
Images: 280
Solve rating: 219
The second seems the newest version.
Post Number:#49 Post Fri May 15, 2020 5:11 pm
Images: 11
Turkey
Thank you ..
-------------------------------- Last edited Fri May 15, 2020 5:34 pm --------------------------------
Is Memory Erase first when I receive the product?
should i perform firmware later? Would this method be useful?
Post Number:#50 Post Sat May 16, 2020 6:30 pm
Images: 280
Solve rating: 219
Just follow the video tutorial.
PS.: Is not needed duplicate your question to get an answer.
